MacBook Repair Extension Program for Hard Drive Issues
acidkiss
Já leram isso? http://www.hardmac.com/news/2010/02/16/fin...01-defective-hd
No site da Apple: http://www.apple.com/support/macbook/hd/repairextension/
Apple has determined that a very small percentage of hard drives that were used in MacBook systems, sold between approximately May 2006 and December 2007, may fail under certain conditions.
Identifying Affected MacBook Systems
Symptom
A flashing question mark appears on screen when the MacBook is turned on.
Affected MacBook models
* 13-inch black and white MacBook models with the following processor speeds and hard drive capacities:
* Processor speed - 1.83GHz, 2GHz, or 2.16GHz Hard drive capacity - 60GB, 80GB, 100GB, 120GB, or 160GB
Eu fui uma das pessoas que teve o HD queimado. Macbook white late 2007, HD seagate. Deixei até relatos aqui: http://macmagazine.com.br/forum/index....ost&p=48078
  • Respostas 5
Idem :)
Há uma notícia boa para ambos ....
Retirado do site da Apple.
(...) Additional Information
Some customers may have paid for out of warranty repairs that qualify under this program. Apple will contact affected customers (where contact information is available) with details on the reimbursement process. If you believe that you paid for a repair covered by this program and you have not been contacted, you may contact Apple Technical Support.
This worldwide Apple program does not extend the standard warranty coverage of the MacBook.
This program covers affected MacBook models for 3 years from their original date of purchase or until August 15, 2010 whichever provides longer coverage. Apple will continue to evaluate the repair data and will provide further repair extensions if needed.
O meu não estaria coberto, pois não é era um MB, e sim um MBP. Além disso, eu mesmo troquei o HD.
Nunca pagaria por um serviço baba desses. B)
Bom, sei lá! HD é tudo HD .... vai no MB / MBP e etc ... Será que com a nota da compra do HD eles não te reembolsam? Não imaginava mesmo que teria pagado para trocarem seu hd ... rs
Editado por Akira
      56.3k
      466k
